cat delete
1.4K views 6 replies 4 participants last post by  TrickyNicky78
#1 ·
has anyone took there cat out and replaced it with a test pipe or a piece of straight pipe?
notice any power gains, i am sure you had too.
how much louder is it?
also what are the 2 cables that look like they run into the exhaust system, i am looking at it with the fairings on, so they may not go into the exhaust but it sure looks like it, it seems like its a valve or something
Richie
#2 ·
I believe its called a SET valve.
I am pretty sure if you replace the CAT with a straight pipe it goona be stupidly loud, will probably run worse (lean) without a remap. Look through the exhaust options post for more info.
You should be aware that most race teams are using a convential style muffler.
#5 ·
Dont quote me on this but I think the SET is used like a EXUP valve and helps to pass emissions tests.
Also, I think the bike runs a lambda sensor to help adjust the fuelling again for emissions tests.
#7 ·
A SET valve is designed to physically alter the characteristics of the exhaust system. The valve is essentially a flap and is rotated to reduce or increase flow through the system. When closed or reduced, back pressure increases within the header portion of the exhaust system, changing the dynamic of the wavefront travelling from the exhaust ports, ultimately aiding in exhaust gas extraction from the cylinders. Your CDi is calculating the position of the SET based on your throttle position sensor and a host of other inputs to optimize the air-fuel mixture which should, in theory, maximize power at any given rpm.
