04 gsxr stretched 8 inches
4 reading
9.4K views 20 replies 12 participants last post by  john kinzell
#1 ·
I would like to know what size chain to run on my gsxr 600 and a good everyday gearing set up for the street? :scratch
#2 ·
Order a chain with +30 links longer than stock. Stock gearing would be a good starting point if you are just cruising on the street.
#6 ·
Id go with 530 myself
#16 ·
I run a 520 chain set. I already went thru one rear sprocket. NOBODY around me had a 520 replacement in stock. I special ordered my original one. Had to end up driving some 45 mins away just to find a used one some race shop happened to have since I had an event to ride to that weekend. Once this sprocket is done I'm redoing the ENTIRE set up back to 525 since that and 530 was the only size all the stores near me had replacements for.... just something to consider. If replacement parts are available in stores near you or is 520 only available to u by mail & patience?
#19 ·
STOP!!!
You have OEM 525 sprockets and you put a 520 chain on them? :wtf It may kinda fit on there if the teeth are tapered but there is no way it's seated all the way between the teeth, it will tear them off in no time.
#18 ·
Oh my fucking god...
For one, you forced a 520 chain on stock 525 sprockets?
